Vridkondensator tips
Här kan man dela med sig av sina upptäckter på nätet.
Inlägg av Hasse Andersson » 27 augusti 2018, 08:41
A way to check old variable capacitors with Insulation PCB
https://www.youtube.com/watch?v=g20VTDLNe24
If you restore antique radio, you may need to
check the variable air capacitor. However you've
probably known it's not easy if the capacitor is old.
There normally are two problems, 1st, the rotor
partially touches the stator in the rotation, 2nd,
it's not touching but gets too close, near touching
somewhere, then the tuning linearity has been lost.
To check and find out the exact location,
so that you can fix the part, High Voltage,
more than DC 1000V.
Insulation Checker Board is useful. Since 1000V
can make approx. 1mm glow discharge in the air gap,
you can see where and which part touching or near
touching in the rotation. In this video DC 1200V
Cockcroft-Walton Insulation PCB shows it with
spark discharge.
Though you'd better use glow discharge only needless
to say.
